Fusion 360 hangs after latest update
blueFuse
blueFuse
when I last closed Fusion, it updated before shutting down. Since then, i have not been able to start Fusion 360. It starts up and at about 80% loaded, the main window comes up (blank) and nothing happens again. I have rebooted, reinstalled, reset, repaired, followed all the Support guides, but no dice. No error messages in Autodesk streamer.log nor in any other Autodesk logs. I'm not quite sure what my options now are ...
Running Windows 11 (latest update), hardware is up to specs, worked just fine till last week :s.
Any ideas?
Thanks!
Mike
blueFuse
Thanks to Autodesk Support we got it fixed. Possibly some leftover registry keys that were blocking it, but a manual clean install (https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-do-a-manual...) did the trick!
