Fusion 360 gives out "unsupported browser" when launching
baykakabay
Message 1 of 8
baykakabay
When I run Fusion 360 with the Chrome browser, it says "unsupported browser" and asks to open in supported browsers, one of which is Chrome.
I tried running it in the Fusion 360 app, and it has the same problem with the unsupported browser PrintScreen.png
Replies (7)
Message 2 of 8
piotr.kornafel
Autodesk Support
Autodesk Support
Hello @baykakabay
At first, you can try to update your chrome browser as following:
Update Google Chrome
If this doesn't help you let try to reset your PC and open Fusion 360 once again.
In the next step, you can try to turn it off for a while your Anti-virus software.
If all those steps fail, please share with me your diagnostic log files below you will find a link to the article:
How to manually collect the log files for Autodesk Fusion 360
Piotr Kornafel
Global Product Support
 Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 8
baykakabay
All the steps had fail
Message 4 of 8
piotr.kornafel
Autodesk Support
Autodesk Support
Did you try to open Fusion in the admin account?
Piotr Kornafel
Message 5 of 8
baykakabay
tried it. the problem is not solved
Message 6 of 8
302731251
Community Visitor
Community Visitor
i have the exact same problem on my computer, it simply does not want to work, its a bit stubborn i think
Message 7 of 8
janne.lindqv1stNDNC6
I have the same issue when I'm using fusion 360 in the desktop app.
Message 8 of 8
snrch4455JDFQ
I know this is a old post, but might help someone later. I just came across this issue on windows. I had to navigate to the following, which might be different for others, something like "C:\Users\<user>\AppData\Local\Autodesk\webdeploy\production\<some long number>". There were 2 folders, you'll want the one with more files in it. find fustion360.exe and launch that. the shortcut was using the one in the other folder which gave me the infinite loop.
