Fusion 360 for Education Usage Limits Exceeded
Message 1 of 20
Hello, I cannot create a new project in fusion360. I am on a student account, which I thought would give me access for 3 years. I've been bounced around to 3 different help lines at this point. The error I get when I try to create a new project is: "Operation Failed. Usage Limits
Exceeded"
Replies (19)
Message 2 of 20
charegb
Hi Steve,
Sorry for the trouble. We are looking into your account and will keep you posted.
Bankim
Message 3 of 20
steven
I am receiving this same error as well, I'm not sure if it relates to the upgrade
Message 4 of 20
innovatenate
Autodesk Support
Autodesk Support
@Anonymous I suspect you're running into that issue because you are currently running a trial of Autodesk Fusion 360. Is this the case?
Nathan Chandler
Principal Specialist
Message 5 of 20
steven
@innovatenate I got the license popup and put it under the "student/education" license, does this only count as a trial and stay limited to 2 projects? Does the startup/enthusiast license allow more projects? I'd fall under either license terms
Is there a way to tell if it is running as a trial? (Fusion 360 on Mac)
Steven
Message 6 of 20
innovatenate
Autodesk Support
Autodesk Support
Thanks for the update. Student/EDU subscription should not limit your projects.
I still see the Autodesk Account still doesn't reflect the student license. You can log into manage.autodesk.com to review this.
Let me check with the back office team to see if we can find anything wrong with the entitlement system. I circle back with an update early next week.
Thank
Nathan Chandler
Message 7 of 20
steven
thanks @innovatenate
I have looked in the account management screen, and it does not seem to have anything relevant in the management page under either products, updates or trials.
I can't see anywhere within either Fusion 360 or the website to change/manage the fusion licenses. The only time there was anything was when it said the trial had expired. (I may be missing something that seems very simple and obvious once you know the trick, and I'm just overlooking it)
Thank you for looking into this further
Message 8 of 20
innovatenate
Autodesk Support
Autodesk Support
I think we have it sorted out now. Can you try again and let me know if you have any issues?
Nathan Chandler
Message 9 of 20
steven
awesome @innovatenate
Brilliant! Just created another test project with no problems, that looks to be working now!
Thanks for getting it fixed Nathan, very much appreciated
Message 10 of 20
I am having the same issue. Usage Limit Exceeded on a student account.
Message 11 of 20
innovatenate
Autodesk Support
Autodesk Support
@Anonymous Can you try signing out and then signing back in?
Nathan Chandler
Message 12 of 20
i have  the same problem here   i need help please
Message 13 of 20
same problem here
Message 14 of 20
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the Fusion 360 Community!
Can you please go to the help menu, collect your diagnostic log files, and post them here? Also, can you please visit A360 and try to sign in. Do you get an error? Are you able to create a new project? Take screenshots of any error messages that occur.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 15 of 20
anders.habo
I get the same message, first try and was planning to go the "Fusion Mastery" tutorial but I cannot create a new project. Get fail message "Usage Limits Exceeded", I have not a student account since I'm not a student but the "1 yr free" for personal use (which is what I plan for).
Any help? Can log in to 360 drive and have no files there (0 byte used). All seems to work fine but starting a new project...
Anders, Sweden
Message 16 of 20
Hello, I get the same error when I try to export my models in stl form.Can you help me please?
Message 17 of 20
g-andresen
take a look at this thread
günther
Message 18 of 20
salu.ylirisku
Same problem here. Educational license as a teacher. Not possible to create new projects.
Message 19 of 20
missyenia
Community Visitor
Community Visitor
I“m having the same issue.
I have a student licence but in the titlebar I still see Personal: not for commercial usage
Can you help me?
Message 20 of 20
TheCADWhisperer
@missyenia
It probably would have been best to start a new thread as this doesn’t sound like the same issue (license type).
Can you go to http://manage.Autodesk.com and post screen shot verifying that you have an Education license?
Do you have two Usernames?
If you Logout of Fusion and then Login with your edu Username does the license change?
