Fusion 360 Failed to Update
Hi guys,
My Fusion360 keeps failing it's updates. I've tried the "cleaner tool" method and I'm still having issues.
Please find the attached logs.
Any ideas?
Thanks!
Here's the cleaner tool I was referring to: How to perform an automatic clean uninstall of Autodesk Fusion 360 | Fusion 360 | Autodesk Knowledge...
Anyone? Help?
jhackney1972
This is one of the errors, all are similar, from your log file.  Make sure you have either configured your Proxy settings correctly for use with Fusion 360 or turn it off.  You did not mention your operating system but if Windows 10, turn off all Proxy setting including Automatic Proxy.
John Hackney, Retired
jhackney1972
Forgot the screen capture.
