Fusion 360: each time I click on TOP (on the cube) the view is upside down
tormy.vancool
tormy.vancool
Something I struggle with since the beginning.
Each time I click  on the upper-right cube on TOP face, the plane goes to the TOP but tis upside down.
Why?
TheCADWhisperer
Click on the rotate arrows.
Right click and set as Home Position.
Use the Home Position going forward.
HughesTooling
Are you saying no matter how the view is orientated if you click Top it always ends up upside down? Fusion normally only rotates the view to the nearest ortho view, so less than a 90° rotation, it does not rotate so Top is the right way up on the view cube.
Mark
Mark Hughes
Owner, Hughes Tooling
tormy.vancool
This I'm able to do I didn't have the need to ask. The problem is: when I click TOP it's always upside down. This is annoying.
tormy.vancool
Right, not mater the previous orientation. I have always to put it oriented as it shoul dbe; I'm wondering why it behaves so.
HughesTooling
Is that something that started recently? I guess the first easy option to try would be reset your layout but that will reset and customisation of toolbars as well I think.
You could also try the repair option from the service utility. Also is your graphics card driver up to date?
If none of that works I guess a reinstall.
Mark
Mark Hughes
tormy.vancool
Thank you.
The repair option worked out. I didn't know it existed, I never got that menu before now. Now it behaves as expected. And I learned something new. Thank you so much.
