Fusion 360 Doesn't Respond (most of the time)
sammuelg
Observer Observer
sammuelg
Observer
Observer
Hello, Fusion 360 peoples. I kindly ask for your help because this is very necessary for my classwork.
I have Fusion 360 (Education License) downloaded on its most recent update, yet for the most part it has almost never gotten past the boot-up screen (the one that just says "Autodesk Fusion 360 on a white BG). When I try to interact with it, without fail, it shows up as "Not Responding". Even if I were to get in, certain features (such as Appearance) don't work whatsoever. I have it on a Windows 10 Dell Laptop with an Intel GPU- full specs at the bottom- but it just doesn't cooperate. What do I do to fix any of this?
Sam
Processor Intel(R) Core(TM) i3-3227U CPU @ 1.90GHz 1.90 GHz
Installed RAM 6.00 GB (5.88 GB usable)
Device ID D70AFA96-7015-4EDB-BAC4-7DEC1689B497
Product ID 00330-80000-00000-AA317
System type 64-bit operating system, x64-based processor
Pen and touch Touch support with 10 touch points
sammuelg
Observer
Observer
Edition Windows 10 Pro
Version 22H2
Installed on ‎3/‎11/‎2023
OS build 19045.2846
Experience Windows Feature Experience Pack 120.2212.4190.0
RajkumarIlanchelian
@sammuelg @While Fusion is launching please click on Ctrl + Shift to launch the Fusion service utility.
in here please run the get system info. It will generate a diagnostic log file .zip that you can attach here.
On e you collect this information can you also try the repair fusion 360 and see if that helps.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
