Fusion 360 -- DB error: // no such table:
jeriesjubran
jeriesjubran
Community Visitor
Community Visitor
Fusion 360 won't start. I keep getting these types of errors:
I tried uninstalling it and reinstalling, restarting the computer and I still get the same error.
g-andresen
Did you use CLEAN UNINSTALL?
günther
mohammed.aliTDPXK
Hello @jeriesjubran ,
Did you by chance accidentally launch Fusion twice? This may be due to this reason.
The workaround is mentioned below.
Please close  all Fusion > go to below folder to delete the db files on your Windows OS > Relaunch Fusion again with only one instance.
C:\Users\{YourUsername}\AppData\Local\Autodesk\Autodesk Fusion 360\Electron\{YourUserId}\lbr\libraries.db
Please kindly let us know whether this workaround is OK for you or not.
Thanks!
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
mohammed.aliTDPXK
@jeriesjubran ,
The below link mentions the complete workaround
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
RajkumarIlanchelian
@jeriesjubran Please follow this link for more updates and workaround - https://forums.autodesk.com/t5/fusion-360-electronics/work-around-for-quot-fusion-360-db-error-quot-...
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
lens42
I today had exactly this problem. This solution worked for me.
