Fusion 360 Create Face Group Not Working
solgundogukan
solgundogukan
When I import the stl model I want to convert it to a solid model. First of all I need to do surface grouping but it doesn't do it in any way. I understand why, I could do it before but not anymore.
When I click on make surface grouping it waits for a while and then stays in the old view. it does not group in any way.
What is the reason for this?
I have tried many different models, even very simple models with a low number of triangles, but without any results.
TrippyLighting
Do you have this enabled?
solgundogukan
Thank you, I was really freaking out.
I did it now and I want to ask one more thing. When I converted it, it didn't convert the model to solid model. It does it as a surface model. How can I do this?
TrippyLighting
Inspect the face groups and see if the Fusion assigned them correctly.
You can edit the face groups.
If you can share the model I can look at it later.
solgundogukan
I guess I didn't quite succeed 😞 I shared the model as a drive. I appreciate your help.
https://drive.google.com/file/d/15MDIQ0gL88DSmNK4KC4t2GCW30piGUm5/view?usp=drive_link
g-andresen
Please share your design directly as f3d and not via an external drive.
günther
solgundogukan
