- Mute
- Permalink
- Report
Firstly: I am wholly unable to submit any sort of error report for this bug. I have no idea why. Fusion simply does not present me with the option.
There was no software update of any sort prior to this that I am aware of. About a week ago I went through my usual workflow, right clicked on a component I wished to save as an STL, the usual box came up asking me to select refinement level etc. I clicked "save" and it began to open the file explorer dialog box to name and save the folder.
Then, the program hung up for 5-10 seconds and completely crashed leaving me no opportunity to file any sort of report.
This problem replicates any time I try to save *any* file as an stl regardless of the project, object, or component. It is not file related.
Seeking assistance, I found a thread on the forum suggesting that Fusion was trying to access a folder which did not exist. This was not true, the referenced folder absolutely existed, but I attempted the suggested fix of accessing NMachineSpecificOptions.xml and modifying the setting 'LastDirectoryOptionId' to reflect a parent folder.
This solution worked, temporarily. I was able to load the save dialog, and from there select the original referenced folder and save my work.
Obviously this is not ideal as I had to keep doing it over and over, so I decided to try the suggested clean uninstall and reinstall option, downloading the Fusion 360 clean uninstall .zip from this site and running it, then reinstalling Fusion from a fresh download.
This made the problem worse. Now, the same crash occurs, but because there is no save history, there is no 'LastDirectoryOptionId' field in my NMachineSpecificOptions.xml file.
As a result I am now unable to even work around the issue by changing the value.
Fusion 360 has become totally unusable to me and I have no way to workaround the issue. As stated, a fully clean uninstall and reinstall did not fix anything despite being attempted multiple times. This is NOT individual file related, as this happens with each and every use of "save as STL" across all projects.
I am still able to access save as dialog boxes when attempting to export as other file types such as .f3d, or exporting render images, but "save as STL" specifically has been rendered totally non-functional.
Please, someone give me a direction to at least try to move in, here.
I am attaching my most current Fusion 360 diagnostic log, though this is from a fresh reinstall so I'm not sure how helpful it can be.
