fusing two files
fusing two files
fusing two files
I have imported two .step files into fusion 360.  They are two 3D blocks.  I can combine the files without a problem.  When doing so it create a line where the two blocks connect.  I need to make it one piece for use in the manufacturing process..  I tried to use stitch but it does not recognize the line, nor does the fill command.  Does anyone know if this is possible?  Thank you.
TrippyLighting
If you can share the model we can move forward.
The files can be found at:
