Message 1 of 26
Fully defined sketch not redrawing correctly after dimension change.
04:41 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Having an issue with sketch objects not redrawing correctly after changing a user defined parameter. The parameter changed isn't used in the sketch, but it changes the position of the geometry that was projected into this sketch and then changed into construction lines (RaspberryPi board outline that two other parameters control the distance from the left and bottom edges). With the 10mm change the added mid point construction line (used for mirroring) moves with the projected geometry, while with a 20mm change it doesn't. With a 10mm change the sketch moves with the projected geometry and gets messed up, while with a 20mm move it doesn't move breaking many features in the timeline. The sketch also references a Pi Boards component edge, with the 10mm change it gets moved to the other side of it, while with the 20mm move it's just completely broken. Looking for some help on what to change to get this sketch to update appropriately when the dimensions are changed.
