Form preview not given
wesley.bonafe
wesley.bonafe
I want to create a seat & would like to start with a flattened box form.  Unfortunately when I add the box I get no opportunity to flatten the box or change the number of faces.  Not sure what I'm doing wrong.  Check out the screencast.
wesley.bonafe
Here we go again.  No screencast. https://autode.sk/3ce1UJl
wesley.bonafe
That ran for me.  Hopefully it will for you!
jeff_strater
my guess is that you are zoomed in too close to see the on-screen UI.  Can you try zooming out?  As for the dialog, have you ever used Fusion with a second monitor?  If so, try Reset To Default Layout:
Jeff Strater
Engineering Director
wesley.bonafe
Apparently I was zoomed in to close.  Thanks!
wesley.bonafe
Well I'm back...
Thought this was a zoom issue but it returned.  Tried resetting my view but that didn't work..
Any other suggestions would be appreciated.  https://autode.sk/3iapKJT
