Form 'Bridging' problem
ekalyvio
ekalyvio
Hello, I am reading the following tutorial:
Getting Started for Absolute Beginners / Introduction to 3D Modeling / Lesson 14: Insert edges, sculpt, and bridge freeform bodies to create the saw handle casing
Could someone let me know why my form after bridging becomes from this:
Smooth surfaceSmooth surface
to this?
Non-smooth surfaceNon-smooth surface
The later seems impossible to process it further. Am I doing something wrong?
Thank you very much in advance.
TrippyLighting
Yes, after the bridging edit the form cannot be converted into a smooth form so it is displayed in box view mode.
In general, you should probably make the shape look smoother in box mode so no faces overlap/intersect as that is probably the reason this does not go back to smooth.
Dan you share your model so we can examine it ?
ekalyvio
Hello. Yes, you can get my model at:
https://a360.co/2y9Ghse
Please, let me know if you find anything wrong with it as I still don't understand the reason the software fails to render the curves.
TrippyLighting
Your edge loop is interrupted there. When designing with T-Spline make sure you think in quad surfaces. No triangles, or N-Gons.
Also, design 50% in box view mode. If thats nice and smooth you'll be rewarded with a nicely flowing T-Spline.
In essence you need to weld these 2 vertices, but than as shown in the screencast clean up the T-Spline a little and move vertices.
ekalyvio
Thank you very much. I really appreciate it.
I have learned plenty a lot from your video on how professionals are handling such meshes!
Now, I see my mesh and I can surely realize that it was a total mess! I should have spent much more time in it!
