Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
Font extruding, excludes the middle bar in the "A"
infoYYJRS
Message 1 of 9
infoYYJRS
Hi friends,
Can someone tell me why i cant extrude the letters properly?
The font i am using is this one:
https://fonts.google.com/specimen/Cormorant+Garamond
Kind Regards É
Accepted solutions (4)
Replies (8)
Message 2 of 9
jhackney1972
There are a lot of Fonts that Fusion cannot properly read due to many factors.  A lot of the time you can Explode the Text and get the results you need.  Another thing you can do is convert your font from TTF to OTF using this site.
I your case, the Font can be exploded.  The video will show this.
Edit: The "A" is poorly created by the creator of the Font.  Use the method I show in the video and then extrude it paying close attention to the profiles in the  "A" cross bar.
If this answers your question, please select the "Accept Solution" icon on my post. If you have further questions, please ask.
John Hackney, Retired
Message 3 of 9
infoYYJRS
Dear John, thanks for the instructions, i guess they did a bad job at google not as precise as i thought they would be 😉
I have a follow up:
I would like to give the letters a fillet all around the edges, abit like car model numbers have. Here i also get errors.
Would you know what this is caused by?
Kind Regards É
Message 4 of 9
jhackney1972
All fonts create bodies with segmented edges.  To use a Fillet on them usually requires you remove these segmented edges.  This is a very time consuming task but if you want to try it, this Blog Article and Video will show you how.  Even if you do this since you have chosen a very narrow bodied font, you will not be able to get more than a 0.25 mm Fillet around the edges.  I copied and modified the "S", using the procedure outlined in the Blog and added a 0.25 mm Fillet to both sides as an example.  Model is attached.
Message 5 of 9
infoYYJRS
Dear John,
I have a follow up question:
How would you hallow out the letters?
Lets say we wanted to cast these in a precious metal, and if so how do you determine the thickness tolerance?
Message 6 of 9
jhackney1972
You are not clear on what you desire.  Do you want the letter hollow inside without opening to the outside or do you want one side removed?  I chose the later in my video.
Message 7 of 9
infoYYJRS
Dear John,
Thanks for pointing that out. To clarify, I'm looking to cast these letters in precious metal, meaning I want them hollow internally—fully enclosed without visible openings or seams. The idea is to reduce material use (for weight and cost), but the exterior surface should remain completely closed and visually unchanged. How would you recommend achieving a hollow interior that is structurally sound and compatible with casting?
Message 8 of 9
jhackney1972
If you want them hollow, without any open sides, simply use the Shell command on the Body without selecting any faces.  You will still need to have a pouring hole.
Message 9 of 9
infoYYJRS
Cool, i just don't know how to?
