FM gears add-in problem
boyleiste
Message 1 of 11
boyleiste
I have been using for a while FM gear generator as an add-in but after the last update I couldn't use it. It gives an error when I try to create a gear which is 'Bad index parameter'. The add-in was very effective and successful for me. It is very important for me to use it again. Because I have been manufacturing my gears developing my prototype accordingly and the GF gear generator do not give the exact same result. They create same module gears with different root diameters. Even 0.057 mm is very important for me. If anyone could help me about it I would very appreciate it.
Kind regards,
Sabah
Accepted solutions (4)
Replies (10)
Message 2 of 11
jhackney1972
I to used this Fusion Add-in.  I wrote to and heard from the author and it would see a recent update of Fusion introduced a variation in the scripting language.  He is aware of it and hope he can fix it soon.
John Hackney, Retired
Message 3 of 11
boyleiste
It is great to hear that. Thank you!
Message 4 of 11
jhackney1972
I wanted to point you to a stand-alone application created by the same author as FM Gears that may be a substitute for FM Gears until, and if, the author repairs it.  It is called GearDXF and it will generate gears, much like the FM Gears Add-In and give you a few file types to work with, not just DXF.  Here is the link.
Message 5 of 11
boyleiste
Dear Mr. Hackney, you are so kind and helpful. This is a great advise. I will definitely try. Thank you very much.
Message 6 of 11
peter.hillis
Seems to be fixed with version 1.4.
Try the following link to download the latest version.  Forest Moon Productions - FMGears   ( https://www.forestmoon.com/Software/FMGears/)
I just shutdown Fusion and then copied the new files overtop of the old Add-in and it worked fine when I restarted fusion.
Message 7 of 11
jhackney1972
Thank You, Thank You, Thank You!  I just installed it also and it works fine.
Message 8 of 11
magic_global_k
Community Visitor
Community Visitor
Hello, I replaced all of the old files with the new files however, when I open Fusion, it does not allow me to run FM Gears. Could anyone help me fix this problem?
Message 9 of 11
peter.hillis
If you go to "Utilities"/"Add-ins"/Scripts and Add-ins" then click on the "Add-ins" tap of the window that opens is "FMGears" listed there?
Message 10 of 11
magic_global_k
Community Visitor
Community Visitor
Once I overwrite the files, it doesn't show "FMGears" anymore
Message 11 of 11
roarraj
The same issue was resolved by installing .Net Desktop Runtime 6.0
