Flatten Surface to Make Pattern
imcbrandon
imcbrandon
Is there a way to flatten the blue surface in the image below? I'm trying to make a paper pattern.
I've attempted the method below, but I'm not sure I can do the combine step in my situation.
https://forums.autodesk.com/t5/fusion-360-ideastation-archived/converting-surfaces-to-sheet-metal/id...
Thanks for any help!
jhackney1972
I have attached your model in a flatten state.  If you just want the flat pattern sketch, you can make Sketch 3 visible and turn off Body 4.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
John Hackney, Retired
imcbrandon
Thanks so much!
