Flatten Complex Curved Body for CAM
HarrisonClassic
HarrisonClassic
So I have a curved part as shown above.
I'd like to flatten this out in order to cnc route the part. Accuracy is not super important as any resultant body I would add a few millimeters on all edge faces for final manual fitting.
My thinking the only approach ( not impossible but lengthy ) is to;
1. pick a central refence point in the middle of the part projected in space.
2. Create a series of offset planes in both Y and Z axis's
3. On each offset plane, create a sketch and project the intersected face
4. Project the plane into the same sketch, then draw a line from there to the projected intersected control point spline
5. Use that intersection to break the control point spline at that point so via the Inspect command I can get the length of each "half" of the control point spline relative to the reference point.
6. Create a set of these control point spline lengths in both axis relative to the reference point, plot them on a sketch and use a fit point spline through the points.
Anyone have any better ideas?
David
David Harrison
Harrison Classic Boats
Win 10 / I7-11700K @ 4.9GHz / 64Gb RAM / SSD's
TheCADWhisperer
I will use the Unwrap command in Autodesk Inventor Professional.
HarrisonClassic
Hey Thanks,
Thought I'd absorb your advice and see if I can make it work myself - so I downloaded the trial of Inventor..
Pretty easy really.
1. Exported the component as an Inventor file
2. Opened in Inventor, selected the main face and did a default unwrap.
3. Saves the new flat surface as DXF
4. Imported into Fusion 360 and voila!
I will only have to do this probably once every few months, so can't justify the $22200 per year, but would just redownload the trial and use it for the 10 mins...
David Harrison
TheCADWhisperer
@HarrisonClassic
You can do the same thing in free Autodesk MeshMixer.
The steps are slightly different.
