Flat pattern / dxf from a side angle with circular models
seluRVKMT
Message 1 of 1
seluRVKMT
Dear Autodesk
A persistent issue I've experienced, is that when creating flanges or similar models, then convert to sheet metal, the resulting sheet metal pattern aswell as the .dxf from the 'Export Flat Pattern as DXF' option is viewed from the side. So that a circular flange becomes a rectangle.
(Viewed from the ZY plane, instead of the XY plane for example)
This happens on and off. I've attached a file in which this problem persists.
Hope you can help. Thank you in advance.
Replies (0)
