Hi, I am just starting to use the sheet metal module. I am making a lid with bevelled edges.
The two problems I have are as follows:-
1. I have sketch lines for the main shape on one plane, (Sketch 13), and then the lines I want the flange to bend to on a second plane, (Sketch 14). I cannot find a way to make the flange bend to a line, it will only respond to the drag and drop or entered values for angle and length. You can see I have aimed close to the lines but not hit them properly.
2. I am making the corners by turning off the mitre option and then forming a 3rd flange from one of the original flanges to meet and then weld to the edge of the other flange. I can only achieve this by creating a plane between 3 points, sketching the triangle and creating a new body, (Body 9).
I have tried all the tricks like projecting lines, Chamfer edges, even creating a flange that is too wide and timing it back later, (this option usually ends in timing both flanges leaving a gaping hole!!
Surely there is a better way that will give me an accurate unfolded view to cut the sheet from?
