[FIXED] - Black Toolbars/Missing Toolbars After the April 27th Update
Hi all,
Some of you may have experienced the symptoms described in this support article. Late last night, Fusion 360 pushed out an update to address and fix this issue. By updating Fusion 360 to 2.0.10148 - the black toolbar issue should disappear.
For anyone who used the environment variable workaround via the support article/troubleshooting - you can go ahead and remove the environment variables once Fusion 360 has successfully updated, as these may cause issues with other softwares.
For those who cannot see or update Fusion 360 to the latest version - if possible, use the workaround in the support article above to add the environment variables temporarily. This will allow you to load Fusion 360. Once Fusion is launched, in the clock icon in the upper-right will be a 1. Click this icon to view the status of the update process, and restart Fusion 360 once the update is completed.
Alternatively - Fusion 360 can be updated manually, by reinstalling Fusion 360 from your products and services page via Autodesk Accounts.
If you need any help, or have any questions, please leave a comment.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
