Fit to screen
Fit to screen
gillesht
Message 1 of 13
Fit to screen
gillesht
Even when in full screen I don't see my timeline at the bottom of the screen. Is there a way to fit Fusion 360 to my screen? I work with a 17 inches laptop. See attached screen capture.
Best regards
Replies (12)
Message 2 of 13
HughesTooling
I just put this in your other thread.
@HughesTooling wrote:
@gillesht After the last update a couple of time I've had fusion start with a window that's taller than my screen so the timeline's off the bottom of the screen. What I had to do was select Restore then drag the window away from the top left corner then select Maximise. Just toggling Restore then Maximise before moving the window didn't work.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 13
gillesht
Sorry but not working.
Best regards
Message 4 of 13
HughesTooling
@gillesht  Looking at your screengrab it looks like the title bar is off the top of the screen as well!
EDIT the second time you press Alt+Space select M for Move.
Try this. Press Alt+Space then press R then Alt+Space again and press M then press the down arrow and the window  should jump to the mouse.
Mark
Mark Hughes
Message 5 of 13
gillesht
I've attached a screen capture of Fusion 360 before I load my project.
Best regards.
Message 6 of 13
HughesTooling
First, don't attach pictures, just paste them into the message. This forum is not good as you can't view pictures and read the messages at the same time!
This is from your first picture and it shows you have history disabled so you will not see the timeline.
Mark Hughes
Message 7 of 13
gillesht
I did reactivate the history after.
Best regards.
Message 8 of 13
HughesTooling
Does it work now? If not what do you see, can you show a full screen grab?
Thanks Mark
Mark Hughes
Message 9 of 13
gillesht
No change.
Best regards
Message 10 of 13
HughesTooling
You don't have history enabled in that picture. You have to enable history per document by the way.
Mark
Mark Hughes
Message 11 of 13
gillesht
How can you see from a screengrab that my history capture is off? Please look at the foolowing screnn grab.
On the last line you see Capturer l'historique de conception that french for Capture history.
Message 12 of 13
jhackney1972
You have it backwards.  If you have the Timeline showing, the line at the bottom of the context menu, when you right click on the top of the Browser, says "Do not capture Design History".  If you do not have the Timeline showing, it says "Capture Design History".
John Hackney, Retired
Message 13 of 13
jhackney1972
Also, set up your Fusion 360 Preferences to Capture Design History every time you start a model.   One last thought, if you still cannot see your Timeline.  Some laptops can be set to run in "Tablet Mode".  This is only available in Windows 10 but it could be interfering with your display.
