Fillet not behaving as expected with extruded sketch and loft command
Message 1 of 1
I've posted an issue I was having about the fillet command and how it behaves with lofted sketches (the edges created by the fillet command are misaligned and don't connect properly. The resulting topology is not smooth as I would expect (and like it should be compared to the first example). This is even more visible if I convert the body to a mesh, there's a lot of extra triangles when the edges are supposed to connect after the Fillet operation) and got a partial solution.
But in the process, I think I have discovered a bug or something that maybe the devs might want to look into to improve or fix. The current behavior is not consistent.
I won't duplicate the full post here, but here's the link to the full post that contains the explanations and the partial solution to the problem.
https://forums.autodesk.com/t5/fusion-360-design-validate/fillet-not-behaving-as-expected-with-extru...
Thank you.
Replies (0)
