fillet cannot be created
wwfeldman
wwfeldman
as you can see in the attached fillet1, i have a circle with 4 circular cut outs.
also, 5 of the 8 corners fillet worked as expected.
the fillet radius is the value F360 "picked" when i clicked on the corner.
i made it a parameter so i can change it.
as you can see, when i fillet the next corner, it fillets, but the line changes form
black to blue. it doesn't matter which corner i fillet, get the same result -
successful fillet, but blue instead of black line
how do i get the corners to fillet?
TheCADWhisperer
@wwfeldman
Add Fillets as placed features, not in sketch.
If you really really want the fillets in sketch then …
Can you File>Export your *.f3d file to your local drive and then Attach it here to a Reply? Someone here will show you how to fix it.
Even your arc cut outs are not efficient technique.
g-andresen
I recommend this way
(view in My Videos)
günther
g-andresen
In the sketch it should go better like this
(view in My Videos)
günther
wwfeldman
hello gunther
experience shows
very nice thank you
my apologies about the umlaut.
