Fillet Between two intersecting curved bodies
Message 1 of 9
I'm trying to fillet a 90 degree intersection which is usually straight forward. My problem is when i try to fillet this particular intersection, the intersection moves inwards aswell. I think it might be because its trying to continue with both of the curves, which is why it forms a point inwards, but I'm not sure. (The reason there's a chamfer where I'm trying to fillet is because i was just seeing if the dame thing happened with the chamfer tool)
Can anyone help out?
Replies (8)
Message 2 of 9
jhackney1972
You gave you model but you did not indicate "where" you wanted the fillet placed.  Add a screen capture and point to the location.
John Hackney, Retired
Message 3 of 9
Sorry about that, have uploaded now
Message 4 of 9
jhackney1972
I do not have any issue placing the fillets you asked for.  You did not specify a radius so I used 10mm.  I tried to select both edges in different orders, but it did not make a difference.  Take a look at the screencast.  Model is attached.
Message 5 of 9
Hey jhackney1972,
Thanks for you help. Just used your model to increase the fillet to a 20 radius (forgot to mention the radius originally sorry) and the same thing happens. It's just not noticeable at a radius of 10.
Message 6 of 9
jhackney1972
I started with you original model and did 20 mm and 40 mm and it works fine.  Attached is the model with a 40 mm radius.  Take a look from the side view, the fillets look matched and no bulging as I can see.
Message 7 of 9
Sorry, forgot to mention it's only noticeable from the front-on back view. If you view view it like that you can clearly see the points, it's just not noticeable in at any other angle
Message 8 of 9
jhackney1972
If this is what you are speaking of, see screen capture, it is because of the rounded end and sides and their influence on the fillets.  I do not know how to change this except to add a small straight section to each edge before filleting.
Message 9 of 9
Thanks I'll see if i can work off of that
