File Save failed with: "ASMInterface::saveSmbFile failed" error
NeilStansbury
Message 1 of 1
NeilStansbury
After briefly editing a previously saved document, a save failed with the above error after a successful `Compute All`.  Export failed along with it.
I then tried a Save As to create a backup, this partially worked closing my existing document, creating a new document and that then failed to save the new file too.
Following these posts:
https://forums.autodesk.com/t5/fusion-360-support/error-on-saving/td-p/9621848
https://forums.autodesk.com/t5/fusion-360-support/asminterface-savesmbfile/td-p/9401696
I rolled the timeline back to a very old copy-paste bodies feature where I was able to save. Rolled forward one feature, save failed again with above error, rolled back 1 and was able to save. I thought I have found the feature with an error.
Thinking this odd that a copy-paste would cause the error, I then repeated the previous steps, rolled forward 1 feature, save failed, roll back to previously saved feature, now that feature would no longer save with the same error.  Roll back one more same error, again & again at no point was I now able to save without the `saveSmbFile` error
Having lost 100s of of hours of work before because Fusion crashed/couldn't save, I immediately copied my user folder with the crash recovery data outside of Fusion for safety.  I had a dig through the logs, and started seeing this:
20230402T084647 I 14568447 PUT 200 https://f360sc.prd.fusionapi.autodesk.com/api/v1/sessions/26703191 - workflow:SLM_heartbeat attempt:0 requestId:f360_SLM_heartbeat__1-642932e6-e8d237c32780463c8dfcfd91 dt=0.34
20230402T084737 E .14565596 NEUTRON_BUG_ALERT(face is not tagged)
Function: validateParametricTagging
File: /Users/Shared/Jenkins/Fusion/client-delivery/Core/Fusion/Server/TagUtility/Objects/TaggingUtility.cpp
Line: 2526
Thread Info: [Name: Main], [Id: 14565596]
20230402T084738 E .14565596 NEUTRON_BUG_ALERT(face is not tagged)
Line: 2526
Line: 2526
The logs then carried on with:
20230402T090804 E .14565596 NEUTRON_BUG_ALERT(Error: entity is not tagged correct, Please report this to Autodesk)
Function: appendPolarisFeatureIdToNameTag
Line: 1194
20230402T090804 E .14565596 NEUTRON_BUG_ALERT(face is not tagged)
Line: 2526
20230402T090823 E .14565596 NEUTRON_BUG_ALERT(face is not tagged)
Line: 2526
20230402T090824 E .14565596 NEUTRON_BUG_ALERT(face is not tagged)
Line: 2526
20230402T090825 E .14565596 NEUTRON_BUG_ALERT(face is not tagged)
Line: 2526
20230402T090847 E .14565596 NEUTRON_BUG_ALERT(m_recipe)
Function: _track
File: /Users/Shared/Jenkins/Fusion/client-delivery/Core/Fusion/Server/Fusion/DesignCapture/DataRef/BrepRef.cpp
Line: 219
20230402T090847 E .14565596 NEUTRON_BUG_ALERT(Error: entity is not tagged correct, Please report this to Autodesk)
Line: 1194
Line: 1194
Realising I was now in big trouble as the errors related to the file I was working on originally not my now new "Save As" document, even though the crash recovery said it was using my new "Save As" document. I stopped and went to make breakfast to consider my life and possible new career choices.
About an hour later, I came back and repeated the previous steps roll back-save, roll-forward-error.  Only this time no error. Roll forward again, no error, again and again each feature saved. I take the risk and roll to the end. The file now saves. I immediately export for safety.
To be clear I changed **nothing** in that file in the mean time.
If support would like my backup recovery folder when the errors were occurring let me know, however the crash recovery file is only 60% of the size I'd expect, so I have no idea what it actually saved, or didn't.
There should be no scenario *ever* that a user cannot save a file - even if it is corrupt.  I now have zero faith in Fusion's ability to save my data correctly or Autodesk's  seeming obsession with forcing me to use use their cloud infra.
This isn't the first time I've had this error, and this also isn't the first time Fusion has corrupted and lost my data, sadly I doubt it will be the last.
For me, the worst part that causes a complete loss of faith is that Fusion 360 appears increasingly non-deterministic.
Replies (0)
