File Save Error (v0)
jsikoraPPGQM
jsikoraPPGQM
I receive the following error message when attempting to save my document: " [CFS] Save of the cloud file Manufacturing Assembly v86 is aborted because it is referencing a local MW1 v0".
If I right click on "MW1" and select "Choose Version" , the most recent version is selected, and there is no "v0" in the list.
If I manually choose a previous version, click "Ok", then select "Choose Version" again and re-select the most recent version, then save the document, I get the same error as before, but with a different component.
Any help would be appreciated.
helloJW7K4
I am struggling with the same error for the first time. Did you find a solution?
jsikoraPPGQM
My current workaround is to open Task Manager and end the Fusion 360 task. For some reason Fusion has no problem preforming an Crash Recovery Save. When I open Fusion back up, I am able to open the recovered file and it saves just fine. That works for me at least.
