File lost...
File lost...
FrodoLoggins
Advisor Advisor
File lost...
FrodoLoggins
It pops up in My Recent Data for a second but is not selectable:
https://youtu.be/VKoTdboAfqQ
This is the file I'm looking for:
I did not delete it. It's not anywhere in myhub.autodesk360.com. Not in any folder I've created, archive, or trash bin.
I moved it (along with a few other files at the same exact time that I am still able to locate) from All Projects > Work to All Projects > Work > Old
I'd ask where the recovery files are saved in MacOS but ya that's broken as well despite being enabled in my settings.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
dsouzasujay
Hi @FrodoLoggins ,
Can you login to A360 and check if your file still exists in the hub?
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
FrodoLoggins
dsouzasujay
Hi @FrodoLoggins,
Do you mind sending up the complete log files?
Help -> Support & Diagnostics ->Diagnostics log files. This will generate a zip file that you can upload.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
FrodoLoggins
Attached
dsouzasujay
Hi @FrodoLoggins,
From the attached .zip files i can see some of your files are struck while uploading.
Please follow THIS link to recover the files stuck in upload queue.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
