File corrupted after save
Message 1 of 10
I was working on a project and after saving and exiting the project was corrupted. I am unable to open the document, I keep receiving an error message 'Could not open file, Error opening file! the current operation will be aborted'. I really need help accessing this document. The Diagnostics log is attached below.
Thank you
Samson
Replies (9)
Message 2 of 10
bharamk
Dear @Anonymous
Sorry to hear about it, Will it be possible to share the file with us?
Thanks & Regards,
Ketan Bharamgunde
Autodesk, Inc.
www.autodesk.com
Thanks & Regards,
Ketan Bharamgunde
Sr.SW Eng.Test
Autodesk, Inc.
Message 3 of 10
The link to the document is https://a360.co/320NNTg.
Samson
Message 4 of 10
bharamk
Hi @Anonymous
Thanks for quick response and sharing link.
We are internally tracking this issue with FUS-68891 and this will require investigation
We will require few more information,
1) Does this file are having multiple versions?
2) Please share the earlier version either by exporting or giving access to us to project.
you can share the project with ketan.bharamgunde@autodesk.com & ahsan.ali@autodesk.com
Ketan Bharamgunde
Thanks & Regards,
Ketan Bharamgunde
Sr.SW Eng.Test
Autodesk, Inc.
Message 5 of 10
The file has 56 versions, I cannot export the file because of the error messages (cannot open). The link I provided gives you access to the project https://a360.co/320NNTg. I do not know of any other way I can share the file.
Samson
Message 6 of 10
bharamk
Dear @Anonymous
Please share the project with us to take a further look.
Here is article how you can add people to your project https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/screencast/Main/Details/8c9b1d8...
Please add the following email
rhudaynath.diwate@autodesk.com
Thanks in advance,
Ketan Bharamgunde
Autodesk, Inc.
www.autodesk.com
Thanks & Regards,
Ketan Bharamgunde
Sr.SW Eng.Test
Autodesk, Inc.
Message 7 of 10
I have added the email addresses as requested.
Samson
Message 8 of 10
bharamk
Dear @Anonymous
Thanks for giving access. Sorry to say this but in the initial investigation from the version V51 to V56 of file found to be corrupt. The good news is that during initial investigation its been found that v50 is good and can be opened successfully.
Do you mind to promote version v50 back and rework for missing data loss?
Do you remember any operations you have performed after V50 before saving to V51?
Just to inform you file corruption investigation may takes longer time and even after complete investigation cannot guarantee of all the data as there are chances of data loss. So this is quick workaround for you, if you are okay with it.
Thanks & Regards,
Ketan Bharamgunde
Autodesk, Inc.
www.autodesk.com
Thanks & Regards,
Ketan Bharamgunde
Sr.SW Eng.Test
Autodesk, Inc.
Message 9 of 10
I am okay with the quick fix, I still remember all the operations after v50. In the future how can I avoid the corruption of my files, what causes it?
Samson
Message 10 of 10
bharamk
Dear @Anonymous
Thanks for Co-operation with workaround suggested. Please promote version V50 and make a copy of that so that you will be having backup of that. could you help us by trying to perform operation on the promoted version and try to reproduce the issue?  If it gets reproducible again then please share the detailed steps or video of steps.
Thanks & Regards,
Ketan Bharamgunde
Autodesk, Inc.
www.autodesk.com
Thanks & Regards,
Ketan Bharamgunde
Sr.SW Eng.Test
Autodesk, Inc.
