Feature Select in Circular Pattern selects extra faces
richard.ballard
Observer Observer
richard.ballard
Observer
Observer
Hi I've found a bug where I want to pattern an extrusion around, however, when I try to select the feature, it selects extra faces and thus gives a bad preview. I've attached images of creating the extrusion, selecting the extrusion and patterning to show the issue. I've also attached the exact same setup in Inventor to show what I mean.
It looks like fusion cleans up the bad faces after the patterning, but the live preview would suggest there may be an issue.
I do note, I am using the same sketch for both features yet this should still work as the features are different.
g-andresen
if you share your design we can take a look
günther
jeff_strater
try a different pattern type than "Adjust" - "Identical" or "Optimized" will likely work for you.
Jeff Strater
Engineering Director
