Feature Request: “Smooth or Flat Interior Option” for the Shell Command
cklyons99
Message 1 of 1
cklyons99
Feature Request: “Smooth or Flat Interior Option” for the Shell Command Summary
Add an option in the Shell command to allow users to generate a simplified or flat interior wall instead of a fully conformal offset of the outer surface. This would provide a faster, cleaner, and more print-friendly inner geometry for organic or detailed models created from Form (T-Spline) or Surface bodies.
Current Behavior
  • The Shell tool performs a mathematically exact inward offset of the outer BRep surfaces.
  • All exterior details (bumps, waves, embossing) are carried into the interior wall, resulting in a highly complex inner surface.
  • For 3D printing, this often increases print time, uses extra filament, and can cause poor bridging or adhesion at steep internal overhangs.
  • Users who want a smooth, flat inner wall must manually reconstruct it using Sketch + Extrude or Surface + Stitch workarounds.
Proposed Enhancement
Add a new option within the Shell dialog:
🟢 Interior Simplification Mode:
  • “Conformal” (current behavior)
  • “Smoothed” (averaged curvature)”
  • “Flat Interior” (planar or simple revolved wall)
When “Flat Interior” is selected, Fusion would:
  • Offset only the base plane if present.
  • Create a simple cylindrical or planar inner cavity following the overall bounding contour.
  • Maintain uniform wall thickness while ignoring local exterior surface detail.
Benefits
  • Dramatically simpler interior geometry for complex sculpted bodies.
  • Reduced print time and filament usage for FDM prints.
  • Cleaner G-code paths, fewer bridging artifacts.
  • Faster shelling operation for large or high-curvature T-Spline conversions.
  • Eliminates the need for manual “flatten-interior” workflows with additional sketches or surfaces.
Example Use Cases
  • Organic 3D-printed planters, vases, or bowls where exterior form matters but interior smoothness is desired.
  • Sculpted lampshades or art pieces modeled in the Form workspace.
  • Mechanical covers or housings where interior detail offers no functional benefit.
Replies (0)
