feature pane size too small
t.houtermanH7N2L
Observer Observer
t.houtermanH7N2L
Observer
Observer
Im always struggling to find out which objects i am editing when adding features that cut through multiple components or bodies that hold their default naming given by fusion upon creation (such as "component 1, 2, 3" etc. and its body is named "body 1".  the problem is mainly due to the pane size being too small or the column layout being too wide in de objects list, so it always only shows: "Compone..."
Is there any way to edit this list to a larger size, or to move the columns?
please see image for more details.
g-andresen
Resize!
günther
HughesTooling
Note there is a grip top left corner so you don't have to undock to resize.
Mark Hughes
Owner, Hughes Tooling
t.houtermanH7N2L
Observer
Observer
Hi, thank you for your input!
In my case the window was apparently docked, and therefore it did not have the resize option enabled on the bottom right. see picture.
thanks again, problem solved!
t.houtermanH7N2L
Observer
Observer
Awesome! this is my solution! much appreciated.
however just fyi, i was trying to use the bottom right corner to resize but this only works when the pane is not docked to the edge of the program window.
 thanks again for your help, problem solved
