Fanuc Turning PP Tool output
larnaf
larnaf
Hello, I have tried searching with no success.  I have a Hyundai HIT-160 with Fanuc 21-T control, using the stock Fanuc turning post processor i get an error stating invalid g-code, the issue is it outputs T0101 instead of T101 , i can edit it VScode but id rather not do that everytime.. how do ii edit the post processor to fix this issue? also how can i add the starting tool (T101) to the end of the program before M30 ?
Thanks In advance
a.laasW8M6T
Hi
To Drop the leading zero
Find the  toolFormat and change the width from 4 to 3
var toolFormat = createFormat({decimals:0, width:3, zeropad:true});
Will the T101  always be the tool added to the end of the program? or do you want it to be the first tool in each specific program that gets added to the end
larnaf
Thank you for that info
Yes, T101 will always be the tool to go back to at the end of the program.
a.laasW8M6T
OK
See attached post processor, it should do what you want
