Failed to Download File. An error occurred: Forbidden: Are you sure you have permission?
sidskiba
Message 1 of 17
sidskiba
I have a single personal use license. I have Fusion 360 installed on 3 computers in different locations that I would access individually. I currently have 3 editable documents in my data panel. The same 3 documents show up on all 3 computers as editable. However no matter which one I try I get the same error message. When I go to myhub.autodesk360.com I cannot locate those files. They are not there. I would ideally like to recover those files but do not know what is broken. I have tried a number of things (like going offline on other machines etc). But I cannot do anything with those files. I cannot change to read only. I cannot open. I tried a re-install on one of my machines and it did nothing. Hoping someone can suggest what I need to do here.
Replies (16)
Message 2 of 17
RajkumarIlanchelian
@sidskiba If this is not visible in Fusion team (the web), can you go in to the project and locate the trash folder and see if it was accidentally moved in there?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 17
sidskiba
They were not in the trash folder either. On one machine I was able to make them read only but now they are gone everywhere. Not on any of my machines and not in the web hub. I guess I will just need to re-create them. Just do not know why the issue or why they vanished now.
Thank you.
Message 4 of 17
RajkumarIlanchelian
@sidskiba I will pass this on to another team to reach out here. They should be in contact very shortly.
Autodesk Fusion
Join Fusion Insider
Message 5 of 17
brian.mark
@sidskibaA support ticket has been created. We will reach out here if we have questions and to let you know the outcome of our investigation.
Brian Mark
Sr. Product Owner-Fusion Team
Message 6 of 17
brian.mark
@sidskibaThe team continues to work on this issue. It seems to be a complex problem. I will continue to update this thread.
Brian Mark
Message 7 of 17
brian.mark
@sidskibaCould you please try accessing your projects now? They were marked as "closed" in our system so we have made them active again.
Please let me know if you were successful or are still having issues.
Brian Mark
Message 8 of 17
sidskiba
One called Phantom Mask shows up in project list. I however cannot open the project as it just gives me similar ???? and Read Access Denied above the data panel area. The ones I was hoping to recover were the Knob one and the X End Motor ones.
When I go to the Web I get this when looking at Phantom Mask:
Honestly if this is a lost cause let me know. I do not want a lot of time wasted if this is going to consume hours and hours of work. I will re-make them if I need to.
Message 9 of 17
sidskiba
When I go to the myhub I get this when looking at Phantom Mask:
Message 10 of 17
brian.mark
@sidskiba  Thank you for checking. The team will do one more pass at troubleshooting and let you know if they find anything. Sorry this is taking so long.
Brian Mark
Message 11 of 17
sidskiba
No prob.....thank you.
Message 12 of 17
brian.mark
@sidskiba  We've updated the Phantom Mask file. Could you see if that works now? If so, we'll update the other 2 files you needed. Thanks.
Brian Mark
Message 13 of 17
brian.mark
@sidskiba  We've also updated the "Knob" and "X End Motor" files. Please confirm if you can access these files now. Thanks.
Brian Mark
Message 14 of 17
sidskiba
No change. Same result with Phantom Mask and do not see the X_end_motor or the Knob file anywhere. Web nor PC.
Message 15 of 17
brian.mark
@sidskiba  We're sorry this is happening. Have you already re-created the projects? We're still working to make sure this doesn't happen again.
Brian Mark
Message 16 of 17
sidskiba
I have not recreated them yet.
Message 17 of 17
sidskiba
I have not recreated them.
