Failed to create new projects
While I have been learning the lastest and greatest features in Fusion, I ran into a problem.
Judging from the posts in the forum, i ttends to happen more often.
I can no longer create projects.
I have reduced the number of projects from 7 to 4, and still can't create a new one.
In Fusion 360 it says: Operation Failed
And when i try to do it on the web page it says: project limit exceeded, you’ve exceeded the number of projects allowed in the A360. ( Startup licence)
I have tried clearing the cache (under support & diagnostics) as is mentioned multiple times throughout the forum. But that doesn't seem to fix it.
Does anyone have a suggestion??
(Added Diagnostic log)
Many thanks!
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
I have fixed this for you - this is an internal error on our side.
Cheers!
Karina
nwagcody
Can I have help too?  mine says this: "Not Allowed PUT /communities/api/user/create for b7a13b853d8c.1696ed6d4c4"
karina.harper
Autodesk Support
Autodesk Support
Hi @nwagcody
The way to get rid of this is to switch to a Team hub - can you try that and let me know if it works?
Here's the article.
Cheers,
Karina
nwagcody
Hi there,
It works now! Thanks so much!
CodyJ
