@hipshakestyle wrote:
Interesting, I do have all those files still but they are titled somewhat differently with a long string of characters after the regular title. example:
_Aeroquip -12 to Hose.619f1a1b-438d-4544-955b-62a26d84a830.f3d
The fact you have files with those odd names points to at some time someone copied files directly from windows file system. Maybe they had a crash and tried copying the files to recover a project. You would have probably found you couldn't open the assembly file before you downloaded it.
I have an idea how you might be able to open and relink the assembly file.
First download all the f3d files to a directory on your computer, including the assembly file.
Go to the file menu then View - Show Text Commands (Ctrl+Alt+C).
Make sure the Txt radio button is checked bottom right of screen and enter Options.DebugEnvironment /show
Now next to the file icon top of screen you should have Open a document icon.
Click open document and navigate to the assembly file and open it.
You should get prompts for each of the missing design and then open to select the missing file. I think if you don't have the correct file you can select cancel.
Select a design for all the missing parts and hopefully the design should open.
I noticed playing around with this you are not prompted the name of the missing file so here's a screen grab of the missing files. I'd guess this is the order to select them.
Mark Hughes
Owner, Hughes Tooling
