F360 Update failure
F360 Update failure
daniel.kurthDWKSK
F360 Update failure
daniel.kurthDWKSK
I've tried a couple of times to update, but get a failure message. Dialogue log attached.
I followed some instructions but nothing helped.
For your information!
It is a company computer and everything is controlled from our IT. We have our own VPN, etc.
I tried it at home without VPN in my own WLAN. But the same there too. I even tried it in safe Windows mode. It always leads me to the same destination. Namely, it stops in the middle.
RajkumarIlanchelian
@daniel.kurthDWKSK The logs shows that you are on a really old version of Fusion 360. Here is what you can try:
1. Delete the Fusion shortcut that you use to launch Fusion (This is important)
2. Go to Add/remove programs
3. Select Autodesk Fusion - MODIFY
This will launch the Fusion service utility
4. Run the repair Fusion from here
This should get you to the latest Fusion 2.0.17457 and also create a new short cut for you. Please let us know if this helps.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
daniel.kurthDWKSK
Sorry for the late response. But I was on a one week business trip and don't work in the office on my PC.
So today I tried out your tip but also get a timeout session everytime at 24%!?
PS:
I actually want to try to avoid uninstalling Fusion completely. Not that I won't be able to install it at all afterwards.
RajkumarIlanchelian
@daniel.kurthDWKSK Can you please follow this article for help with the error you are receiving?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Fusion-360-won-t-l...
Autodesk Fusion
Join Fusion Insider
daniel.kurthDWKSK
The instructions which you're sent were the instructions I tried before.
I have now uninstalled the program after all. And lo and behold, the installation breaks off as feared.
I will now contact my internal IT service. I think this is where the problem lies....
