F360 unable to solve simple Isosceles Triangle
Cheesecannon25
Cheesecannon25
Using Parametric Design in a sketch, I cannot set the base of an Isosceles Triangle (given angle) to the result of a function parameter
davebYYPCU
Red text usually boils down to incompatible units.
Cheesecannon25
It's in mm, so that shouldn't be the issue
davebYYPCU
Given Angle and MM,
I’ll let you work out why it’s not working.
MoshiurRashid
Hello
Thanks for posting. Please check some things in your file.
1. The parameter is set in the equation command.
2. The value of the parameter is not high or low enough to violate another value.
If there is still a problem. Please upload the f3d file here so that we can check it.
(files> export> f3d)
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Cheesecannon25
The resulting value is 30mm, which works perfectly when plugged in manually (and, theoretically, any value should work). Sending f3d file.
Cheesecannon25
It seems I used the wrong function parameter, and it works fine now
