F360 thinks it's on windows 10 but it is really on windows 11. Causing a possible problem with taskbar.
mark
mark
I'm on windows 11, build 22000.795.  *BUT* F360 help says it is windows 10.
F360 Version from help window ...
    2.0.13619, Active Plan: Fusion 360, Personal
    Windows 10 Home 21H2 x86_64 (22000.795)  <<<<< WRONG
This may be a cause of a problem with the icon misbehaving on the taskbar.  See https://forums.autodesk.com/t5/fusion-360-support/multiple-fusion-icons-on-taksbar/td-p/11195842
jhackney1972
The issue you have given the link to, in another Forum post, probably is not related to the Windows operating system you are running.  I have had the same issue and I am running Windows 10 Pro.  I agree with you on one point, the About Fusion 360 on a Windows 11 computer does list the operating system as Windows 10.
John Hackney, Retired
mark
FYI:  There is now a solution to the icons on the taskbar problem.  It is in that thread.
