F360 since their latest update, cannot save .stl or import
FacebookGroupMember
FacebookGroupMember
What's up with F360?, all of a sudden since their latest update, cannot save .stl or import. It just crashes. Thanks!
FacebookGroupMember
It's also been a bit unstable. Plus, a few of the add in apps won't work. Hopefully they will read all the crash reports and get it fixed soon.
Phil.E
Are you sending in crash reports? Can you share a report number?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
FacebookGroupMember
I replied on the forum with this issue yesterday, yet still no answer as to where these report numbers are. If i knew, i would send one,
HughesTooling
As the problem is import and export.
@Phil.E  Sounds a bit like the problem where the last used directory for an import or export is no longer available.
This post has the workaround\fix.
Mark
Mark Hughes
Owner, Hughes Tooling
Phil.E
Update: A likely cause has been identified. Please help confirm.
See message 15 here.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
