F360 DXF export from sheet metal flat pattern - Ghost & broken geometry.
Luke_Parf
Luke_Parf
Hi all,
I'm having some trouble getting Fusion to export a flat pattern correctly.
The sheet metal part I am working on has a text cutout which, when our laser cutter is loading in to their nesting software is producing some strange geometry issues.
Workflow to export DXF for laser cutting has been:
Create flat pattern > Create sketch on surface > save sketch as .DXF
Images of what is appearing at the cutters end attached alongside the .F3z part file.
EDIT: I should add, I have tried exporting the DXF and opening back up in Fusion & another software and it opens and appears correct.
hamid.sh.
If you say when opened in Fusion or another software DXF looks correct I don't think problem is in Fusion's side.
I also converted to DXF, directly from flat pattern (i.e. without any sketch) and opened it in CorelCAD, it's fine.
DXF is attached.
Hamid
Luke_Parf
I had this suspicion but I was hoping it was something I could fix on my end.
Thank you for checking it out, Hamidsh.
Luke
Luke_Parf
Hi Hamidsh,
I sent your .DXF through to the cutters and it went in to nesting without a hitch. I'm not sure why it worked but I'm accepting you as the solution.
Thanks again!
Luke
hamid.sh.
Glad it helped. I made my DXF by directly exporting the flat pattern (check out here for the details). It can be that when you did it via a sketch projected geometries caused problem.
Hamid
Luke_Parf
Gotcha - Haven't used that function since starting mainly because our sheet metal cutters don't like having the bend lines on the DXF.
Will bear in mind for the future!
