F360 Drawing partly hidden and not centred in frame & display issues
hansvaneven
hansvaneven
I have this issue coming back since a long time even with the latest Nvidea drivers.
1. when I create a drawing from design
2. then update the F360 design
3. update the drawing, sometimes part of the design is missing, as if the frame is not centred in the drawing frame, I can't seem to find a solution and this issue is coming back since a long time
In some cases using visible edges some parts are completely invisible.
It shows perfect before the drawing update but becomes buggy after the update (small yellow icon on top)
I tried everything but can't seem to find a solution other then redo the drawing which is quite time consuming especially with several sheets, anyone has a solution for this ? Can I manually update the frame ?
This is one of the parts I really hope can be updated as it's not very confortable to make drawings in F360
thanks
hansvaneven
Also in some cases the drawing shows shaded with hidden lines while the appearance options I select shaded, really tons of bugs in the drawing environment when you update a design
hansvaneven
I have found a solution for now, after two hours of trying out but please Autodesk update this as it's an annoying bug :
1. update drawing (clicking on the yellow icon on top)
2. save drawing
3. close drawing
4. reopen drawing
5. open drawing view options
6. change from current scale to new scale and then back to the current scale & change from shaded to hidden lines and back
7. view back
cheers
-KyleWilliams-
Hey @hansvaneven
These sound like graphics issues to me.
I would suggest you try the following.
First thing would be to Clear Cache
Then I would follow This Link below to setup Fusion graphics, specifically for the drawings environment.
Let me know if you still experience the issues after that.
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
hansvaneven
Thanks Kyle for the answer. I'm not sure it's a graphics card issue, What's strange is that my workaround did solve the issue without changing anything. I also updated my graphics card and will try to follow your points and see how this works on future projects. This has been an issue for a long time so I'd really like to get rid of it. thanks
