F360 doesn't load on the right screen anymore
hansvaneven
Message 1 of 11
hansvaneven
since a week or so F360 doesn't load on the right screen anymore. I use a 3 screen setup and before F360 always loaded correctly but now I need to reposition the F360 window each time I load F360 is there a solution to this ?
thanks,
Hans
Replies (10)
Message 2 of 11
tasha.addington-ferris
Autodesk Support
Autodesk Support
Fusion usually launches on the same screen that it is closed in.
One thing you can try:
  1. Launch Fusion.
  2. Drag Fusion to your main desktop screen (if it is not already there) and close Fusion.
  3. Launch Fusion again and drag it to the screen you would like it to launch on in the future.
  4. Re-close the software.
  5. Launch Fusion one more time.
  6. Does it launch on the screen it was last closed on?
Tasha Addington-Ferris
Autodesk Fusion
Technical Support
Message 3 of 11
hansvaneven
thanks, that's indeed how it worked before, but no, now F360 always starts on the left screen even if I close it on the two others. Ans sometimes F360 opens on the whole screen and sometimes it just opens as a very small window. Strange as I never had any issues with this before.
Message 4 of 11
Autodesk Support
Autodesk Support
What OS are you working on? And how are the monitors all connected?
Have you tried disconnecting the monitor setups to reset the connection with the main desktop?
Autodesk Fusion
Technical Support
Message 5 of 11
hansvaneven
I'm using Windows 10 64 bits and I'm using 3x DisplayPort cables in an RTX3080Ti card , but all worked perfectly before and all other apps memorise this setup without issues except Skype, never had any issues with F360 with so far. It started one or two weeks ago so I wonder if it might be because of an update ?
Didn't yet disconnect the setup will try that thanks
Message 6 of 11
hansvaneven
Just tried that nothing changes F360 always starts on the main monitor not on the two others.
Message 7 of 11
Autodesk Support
Autodesk Support
Okay, there was an update yesterday so if you haven't already, go ahead and install that to confirm it still happens.
Otherwise I think a good place to start would be to have you grab your Fusion 360 Diagnostic Log files.
Autodesk Fusion
Technical Support
Message 8 of 11
hansvaneven
Thank you will see if it's already installed and come back to you
Message 9 of 11
hansvaneven
My version seems to be V.2.0.13168 from Monday so that should be the latest version I think.
Message 10 of 11
Autodesk Support
Autodesk Support
Okay I reached out internally and it sounds like this is a known issue being investigated by the development team. I don't have a timeline but usually a fix would be rolled out in a future update once they are able to resolve this.
Autodesk Fusion
Technical Support
Message 11 of 11
hansvaneven
Thanks a lot for asking,I think a new update is planned in July or so no ? Anyway good to hear it's a known issue. thanks
