Extrusion Direction Glitch
benjamink94
benjamink94
This is not the first time I have encountered this problem, but wondering if there is any known reason for this. I am extruding a profile in one direction, and when I press enter it inverts the direction. It works fine to proceed with the negative direction in this case but if I was extruding to an object I am not sure what kinds of links would be kept or get messed up as the design progresses.
jhackney1972
Please attach the model you used in the video.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
