I have to model this absolute mess here. Its a texture that will allow the sheet to bend when laser cut in real life. Ive applied the pattern to the sheet, but cannot extrude it. This happenes because when I select the sketch it also selects the edges and lines. To extrude, I only need to highlight the "profile" which is the center area, but I dont want to have to do this manually 300 times. Is there a way I can hide the edges / lines of the sketch as these are not in the hide & show menu when right clicking the sketch? Or any other way I can push this texture into the plane to get those holes? Thank you!
