Extruding text into a solid, works sometimes, but mostly not?
09:29 AM
I was following a knowledge base demonstration, where I make a quick solid plate and then start a new sketch on the face and add some text to it, then extrude that test inward to make a cut out. I do not know what is happening, but my first line of text in my test worked! Any attempt at repeating it with another line fails.
Inconsistent edge/face relationship.
What might I be doing wrong?
BTW, I did just stop my sketch, and my first extruded test is missing letters in the extrusion..
The order I did things was to make the solid, select the surface for the new sketch, add some text and extrude it down -5mm which worked. Then add the two Unicorns as SVG's, then add more text.. Could the insert SVG mess up my solid?
