Extruding Sketches Changing Colors
burnsx46
Observer Observer
burnsx46
Observer
Observer
I've been modeling all morning with extrusions appearing in grey as I have always expected as normal. The latest extrusions have each come out in a different color, which is not what I want. It is not possible to change the material properties or color or finish of these new extrusions. How do I return the program to the default method of operation?
jeff_strater
most likely Display Component Colors got turned on.  Try just toggling it off:
Jeff Strater
Engineering Director
jhackney1972
For a permanent change, set your Preferences in the panel I show.
For a change to existing, press "A" on your keyboard, or go to Appearances, and simply drag the base appearance over the one you want to remove.
John Hackney, Retired
burnsx46
Observer
Observer
Thank you for this answer, Jeff. It worked!
Burns Baxrwe
jhackney1972
It is customary when someone gives you a solution that satisfies your needs and answers your question to mark their post with the "Accept Solution" icon.  @jeff_strater  gave you a solution that your acknowledged worked for you so please select the "Accept Solution" on his post.
