extruding pipe
extruding pipe
extruding pipe
on the sculpting enviroment, lets say i have a pipe 8x8 faces, is there a way o extrude all the faces at the same time?
g-andresen
Please share the file.
File > export > save as f3d locally  > attach it to the next post.
What do you want to change?
günther
hi thanks for your answer, i want to create a pipe and extrude all of its faces at the same time. to create that knurl effect without sweeps and stuff
azimshaikh95
Hi @Anonymous , I would suggest you apply Knurling Appearances only instead of creating the complex geometries if you're looking for the visual / rendering purpose only.
Thanks & Regards,
MohammedAzim Shaikh
 Please use the Accept Solution button to mark any posts that provide the answer or solution.
 Likes are always welcome.
 LinkedIn | Instagram | Facebook | YouTube
it is for printing casting, so it requieres certain size that im not sure i can reach with the knurling way
