Extruding a spline split body
eykrik
eykrik
Hello, I have problem after cutting the body into two bodies after spline. I want to extrude the innermost part of the face (shown selected in image). Extrude, move and push/pull wont work as they usually do, since extrude deforms the curvature. Please help.
In the picture using the press pull command.
dsouzasujay
Hi @eykrik ,
What final result are you expecting? Are you trying to join the two bodies, or extend the geometry by a specific distance?
If you could share a simple hand sketch or an image showing the desired outcome, that would help us understand your goal better.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
eykrik
Yes i would only like to extend the parts that are shown on the image by 8.5mm toward x axis. I do not want to join the bodies. Extrude and press pull commands will not work as they usually do, they deform the curvature.
jeff_strater
If I understand your requirements, here is what I would do:
  • split the body using a plane, somewhere else
  • move the two bodies by 8.5 mm
  • re-join the bodies using Extrude
(view in My Videos)
Jeff Strater
Engineering Director
eykrik
Okay, that seems pretty clever, will try, thank you 🙂
TheCADWhisperer
@eykrik
What hasn't been mentioned here is that there are quite a few unresolved errors highlighted in your design Timeline.
Run the Ctrl b command (CMD b on Mac)
What do you observe?
Would you like to learn how to fix all of this and avoid issues in future designs?
