Extrude to object cannot complete extrusion
poporacer
poporacer
I have an arch model where I want to add some support "rails" along the bottom and top parts of the arch. The arch will have alignment nubs so that the parts will "lock" in place. I am sure I took the difficult road. I drew the profile to match the Arch and then extruded it to the correct length. Then I created a sketch on the face the is butting up to the alignment nubs with a space for clearance. I tried to extrude the faces to align with the upper portion of the rail and tried to extrude to an object and selected the face of the rail and I get the error. I think it might be because the object face I am selecting to extrude to isn't parallel to the face that I am trying to extrude?
I can extrude it to a distance and get close, but I am wondering if there is a way to extrude this so that it aligns with the edge exactly? Or just get it "close enough"?
Is there a better way to do this to begin with instead of drawing a profile and then adding the "fill"?
davebYYPCU
Hide the Hoops, change this Extrude to include the material you are looking for.
Combine > Cut - (keep Tools) the hoops from it, and
then Mirror, will have both the same.
Might help...
poporacer
That is easier, the only thing is that the cutouts need to be slightly wider than the arches for clearance. Is there an easy way to do this?
davebYYPCU
Make a dummy wider slot as a solid body,
pattern that with the same spacing as the arches,
use them to cut the slots, and not the arches.
Might help....
