Extrude : offset is reversed
AD_AM
AD_AM
Hi all,
I'm trying to extrude profiles up to a sketch point with an offset. When I set the offset to -0.5mm it appears fine but when I click OK on the extrude tab the dimension is wrong and it added 0.5mm.
I've now discovered the offset dimension is reversed, meaning it will add the opposite of whatever value I try while showing what I want before validating the extrusion.
I have made a screen capture of the issue. It started before the most recent update but wasn't fixed when I updated today.
If I open a new file just to test this bug it doesn't appear and all works as intended. Not sure what's causing this file to have the issue.
steve3957T
This happens to me often, I believe it's a bug.  It happens to me if I draw a window to select multiple profiles instead of selecting individual profiles one at a time.  I think it started with the october update.
